Iaherper
My 2019 Bighorn was stolen, I did the Uconnect Gardian thing. They came back after the truck was found and told it was unable to be located, ok , whatever. The only thing damaged on the truck was the positive battery cable broken where it meets the post. Had a dearer take a look and they said there was enough left on the cable , they drilled a new hole and hooked it back up. Everything works on the truck except my display. No blue screen , nothing. They then said that if I replaced the battery cable/ engine harness that it would all work. I have a hard time believing that the engine harness ( quoted at $1000 and a 2 week wait, mind you) will fix the display. Every other person , including a friend that is a service tech at dodge agrees. Are we all crazy? Could it just be disabled by Uconnect?
