Hogfish823
Had my AC thermostat replaced back in April. Just within the last few days my AC started acting up. Any suggestions on what might be the issue? Here is what it is doing.
Setting is on LOW with AC cooling button turned on. It will be blowing nice and cold at the proper speed and out the proper vents. Then it will start to blow warm air that smells like ozone / mustiness. It will do this for several minutes (10 plus) and then start blowing cold again. Or if once it starts blowing warm I turn off the AC Cooling button and let it just run for 5 or 10 minutes and then push the button to cool again and it will blow cold.
Any thoughts?
Any thoughts?
