First time caller here.... about 2 months ago I purchased a "certified pre owned" 2022 ram 1500 classic 2wd crew cab with the 3.6, 850re transmission and 38,000 miles on the odometer.
Just a few days after closing the deal, I noticed a strange vibration on deceleration between approximately...
Hi everyone I have a 2009 Dodge Ram 1500 (4th Gen) 4X4 3.55 Rear End. Im experience a noise from under the truck and not sure what is making it. I ran truck with tires, brakes, rotors off and recorded a video of it. After this i removed driveshaft, pinion turns fine, can not feel any in/out...
I destroyed the Dana 60 case on my 04 1500 4x4 and all i could afford was a used 9.25. I didnt notice that it was a 9.25 at first or I probably would have passed. My original plan was: Swap my carrier since it is a 3.92 LS and the donor case has 3.55 open diff. Now I have 2 questions:
1. Will a...
For those of you with life TD trucks are y’all upgrading the front and rear axles?
What LSD and gears are y’all using For both axles?
Thanks for the help.
My 2019 Big Horn makes a squealing and groaning noise when I turn at low speeds, like in a parking lot or going around corners. It sounds like it's coming from the rear end, but can't be sure. It happens when I turn in either direction. Has anyone else experienced this?
Good Morning Everyone,
I have a 2004 Ram 1500 4x4 with the 3.92 ratio. My son was driving the truck at the time and didn't realize that it was leaking from the rear seal and in time, heated up the housing and stripped the ring/pinion gear. I replaced the gears and seals, but there was a small...
Looking to do a complete rear end swap using a 1998 Dodge Van 2x4 rear axle into my son's 1996 Ram 1500 4x4 pickup. Both differentials are 9.25 w/ 3.55 ratio. Seems a close match but we have noticed differences in the brake shoes, brake hardware and drums. Will obviously need to buy...
I have a 2017 1500 Express 5.7l.
I know, I know, I shouldn't be rolling around town peeling out everywhere, and I don't. BUUUT,
Where I live, North of Los Angeles, there are lots of compact dirt fields and roads that its admittedly pretty fun to go romp around in.
Lately at 35k miles, I get...
I have a 2012 1500 4x4 Laramie. 125,000 on it. For about a month I have a even pitched whine from the back. Thought it may be a wheel bearing and changed out both. Still there. It starts at 30 and peaks at 45mph. Goes away at about 55mph. Seems to be most pronounced slowing to a stop...
Popped cover off as truck was clanking on slow turns and tires dragging. Metal dust in fluid and about 8 good chunks of metal. Clutch pack on driver side looks broken.
Can I pull the ring and diff assembly by popping axle clips slide them out a bit to pull assembly? Rebuild or replace with new...
