Bagpype
Hello.
New member here. I just bought a 2003 Ram 4.7. It starts up and runs very well. When I push the gas hard, up at 3-4k rpm the engine cuts and does instantly. This happens in park, neutral or under load. Every time. I am lucky enough to have a neighbor with the same generation Ram that runs so here’s what I have swapped so far:
Throttle body and all sensors attached, crankshaft position sensor, mass air flow sensor, fuel pump. Fuel pressure is around 50 psi and stays there when it cuts off. I am thinking of pulling the injectors next and cleaning them in my ultrasonic cleaner. Any suggestions or direction pointing would certainly be helpful and appreciated…
