dldb7989
I had a transmission replaced last year and ever since I have had a vibration when driving over 40. This can come and go mostly it is there. The higher the speed the more the truck will shake, mostly can be felt in the drivers seat. Since the transmission was replaced the Ram service department has done the following: road tested with new rims and tires from another truck, replaced the all ready new tires that I had put on when the transmission was done, replaced the half shaft in front, replaced the driveshaft (this was done a month ago), none of this has solved any issue with the vibration. No vibration in steering wheel. Tires have been road force balanced, and alignment done. Any advice, ideas on what this could be?
