TheMick
2014 Ram 1500 Laramie 5.7L 4x4: Initial concern was hearing a loud fan-like noise between 15-15 MPH for a week, then check engine & traction control illuminated. Mechanic put reader on, 18 DTCs: ABS-PCM. Advised taking to dealer in hopes they might know the cause versus going down the list costing more for guesswork. Cleared codes and truck ran fine for a week before same issue, only this time once traction light came on the truck stayed in the same gear slowly decreasing max mph to 40. I'd pull over, turn off for a few, restart with no light and drive for a few miles until the issue returned and I repeated the process to get to a reputable mechanic safely. They repaired a broken wire and called it good. I drove a quarter mile and the same issue returned and I took it back. They replaced the VVT solenoid, camshaft and crankshaft position sensors, and engine intake manifold gaskets. I drove it the same distance and the same issue returned and I took it back. After a week, I approved their request to send to local Dodge dealership. They show code P0334, truck in limp mode, then code P1524. They replaced oil pressure sensor, cam sensor connector, same codes resulted. Dropped oil pan to find metal shavings and pieces of timing guide. Said the engine will need replaced! Replaced oil pan and parked outside while I figure out finances between 2 quotes $8,400-9,500. I'm leaving out all my personal dilemmas to stay focused on the truck's issues and see if anyone has experienced the same or similar with a successful resolution.
