DodgeV10
- Joined
- May 21, 2013
- Posts
- 9
- Reaction score
- 4
- Location
- Omaha, NE
- Ram Year
- 2015 2500 4X4
- Engine
- 5.7 V8
Maybe I'm too picky. Maybe its my OCD. I have a 2015 2500 5.7 single cab long bed 4x4. I just put in a new t-stat and put in new antifreeze with the amount that came out. About 3/4 of a gallon. The OATS stuff. 70-30 mix. However, I mixed it with tap water and not distilled. At 30%, I don't know if that matters.
I have also done the V6 e-fan mod. I did not adjust the computer to turn on the fan sooner.
I have never had a problem driving, tow, or anything I normally do with the truck. I live in Omaha Nebraska. Flat land and major HEATWAVES. Went on vacation pulling my #3500 travel trailer and traveled a crossed the states and everything was well, until I tried climbing the mountains. I saw the needle climbing fast and pulled over just as it "dinged" for overheating. Let it cool. Took my time after that and stopped often until I got to the top. Also had the AC on to keep my fan going. Besides putting in a override switch to keep the fan on with the AC off. What else can be done to help keep the engine cooler? Is there a larger radiator that I can replace it with? Should I put in some aux fans in front of the condenser? Better water pump? Looking for recommendations.
Note: I had taken the manual fan out because it locked on and it sounded like a 747. Major power drain! I figured now was a good time for the e-fan.
Also, Temps for the oil was very hot too. Suggestions on Oil coolers that work are welcomed too.
Thank you for reading this.
