2016 Ram 1500 AC Outlet Issue
MattR
New York
Hey all, so short story, I got all the parts I needed and installed the AC outlet in my ram 1500 express that doesn’t come with it from factory and it will not work and have installed the inverter and necessary harness.
Long story: My 16 ram 1500 express doesn’t come with the 115v outlet and I wanted to add it. From what I figured and read here if I got the necessary parts I could install it. I found a write up on here and bought the outlet, inverter, and harness under the seat. I installed everything and tapped 12v supply to I believe it’s pin#5 on the connector from the cigarette lighter to test if it works. Well no matter what I can’t seem to get it to work so I’m looking for any insight on what to do. Thank you
