Lb29
Finally figured out what was wrong, the idiot put the wrong fluid in the transmission. I changed the fluid out with mopar atf 4 when I dropped the pan I noticed he ran the bolts on the transmission in way to far it cracked the aluminum internal housing causing the fluid to leak from the bolt holes. But after changing fluid and sealing off the bolt holes I drove it and it’s back to normal now
