RamDiver
- Jan 23, 2022
- 2,225
- 3,696
- Location
- Marlborough, Ontario, Canada
- 2021
- Hemi 5.7
If you are going to try it, make sure to recheck those pins on the IC, looks to me like there could be bent pins or solder smeared across them. any corrosion, use a tooth brush will help, most of that board is has nothing on it , If you have to do any soldering , use electronic solder, resin core, not acid core, and a fine tip iron. If that is solder *** on those pins , you will have to clean it off before you try it, you can use copper wire with the iron to suck off the old solder, then just a small bit of new solder. If you have not done this stuff, take it to a TV, radio shop and see if they have a service teck to clean it up for you.
I am 1/2 a world away, or I could do it for you. IF it's just crud , use a pick and clean it up, no power hooked up till it's done. the green on the board will not usually sort it out, just make for poor connections.
You may already know all this , sorry for the long post, Good luck. If there was no power when wet, it may be fine.
I trust that you're referring to the use of solder wick when you say to use copper wire.
Desoldering Braid And Solder Wick | Safest And Fastest
Soder-Wick, the world's leading brand of desoldering braid, is the fastest, cleanest and safest wick in the industry. It significantly reduces rework/repair time and minimizes the risk of heat damage to the board. Solder Wick is available in the most comprehensive variety of widths, lengths and...
www.chemtronics.com
How to Use Chemtronics Soder-Wick
https://www.chemtronics.com/desoldering-braid-wickGrant Price of Chemtronics, takes you through how to use solder wick to repair different types of electroni...
www.youtube.com
