21 ram 2500 died after hard stop
Jpress82
Watertown ct
6.4 hemi
Hey guys, after I stopped hard my truck sputters and dies. Now it won't start. Turns over but nothing!!!! Any ideas to start troubleshooting? Thanks for the advice
Trailmaker
Locked and Loaded
Conroe Texas
2021 PW
The fuel was low?
I had a 96 dodge that done that. Ended up being the crank shaft position sensor.
Trailmaker
Locked and Loaded
Conroe Texas
2021 PW
Can you hear the fuel pump prime up when you turn you key to the on position or push the button with out touching the brake?
jr27236
New York
Possible that it triggered the inertia switch or an emergency fuel supply shut off switch and shut your fuel pump down, if these trucks have them, which they should and may be located on the passenger side wall under the glove box. Others should chime in hopefully to clarify.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
Jpress82
I can't help with your vehicles issue ..........
I just wanted to Welcome you to this forum
I lived & went to school in Watertown, Connecticut
Baldwin Elementary
Swift Junior High
Watertown High, when it was just off Main St. & Echo Lake Rd
Lived out beyond Lake Winnemaug
GTyankee
3.0 ecodiesel
  • This may not help, but
  • Fiat/ Chrysler recalled some 2021 Ram 1500 vehicles with 5.7L eTorque engines due to a software issue in the powertrain control module that could cause the engine to stall.
2021 Ram :
There is no old fashioned, re-settable rollover/inertia switch. The vehicle dynamics sensor is a part of the ORC module.
"The Occupant Restraint Controller (ORC) is a sensing and diagnostic module that is responsible for monitoring and managing hard wired inputs, outputs, bussed messages and contains the vehicles Dynamics Sensor"
JayLeonard
6.7 L Cummins
Jpress82
Baldwin Elementary
Swift Junior High
I worked in Watertown for close to 20 years when the Torrington Company built a manufacturing facility in the industrial park. They still manufacture the steering intermediate shafts for the Ram trucks. Now named Global Steering Systems.
GTyankee
3.0 ecodiesel
That whole area was Farm Land, when i left there in 1962
It sure has changed since then.
One of my Sisters worked at the VFW on Hwy 6 close to Buckingham St. until recently
chri5k
USA
Diesel
So he should take it to the VFW to have it looked at??
GTyankee
3.0 ecodiesel
Maybe for his body, not so much for the vehicle :)
Maybe he can take his Ram to the next town & let the W.F. Kaynor Technical High School Students work on it
They have an excellent Automotive technology course
BillLee
Tennessee
Hemi 5.7 e-Torque
Yes, it sounds like the emergency fuel pump shutoff, in case of accident, was triggered. Usually its a quick reset of a switch or circuit breaker. Not sure where to find it on the Ram.
BillLee
Tennessee
Hemi 5.7 e-Torque
Fuel pump shutdown mechanisms on 2021 RAM 2500 in emergency situations​
The fuel pump shutoff switch is designed to stop fuel flow to the engine in the event of a moderate to severe crash, as a safety precaution to prevent fires or other hazards. If your 2021 Ram 2500 experiences an emergency shutoff, follow these steps to restart the vehicle:
  1. Switch off the ignition: Ensure the engine is completely shut down.
  2. Check the fuel system for leaks: Inspect the area around the fuel tank and lines for signs of damage or leakage.
  3. Reset the fuel pump shut-off switch: Locate the switch behind the right rear quarter trim panel, near the liftgate. Push in on the red reset button to restore fuel flow.
If the vehicle does not restart after three attempts, it is recommended to contact a qualified technician for assistance.
Marshall
Sk, Canada
2014 sport
That is my son's gig these days , after pulling wrenches for yrs. They have some neat toys in the shop. ( out on the coast)
