4WD Auto not engaging
Pastor Bob
Carthage Mo
I did a quick search and didn't see this topic. If it has already been addressed, please point me in the right direction. I have a 2023 Limited 1500 and was driving in wet conditions at highway speed. I tried shifting from 2WD to 4WD Auto by pressing the button, and the 4WD auto button would flash and the 2WD button stayed lit. After a period of time, a message lit up stating " Serv 4WD". When I arrived at my destination, I did a quick youtube search to do a little research, since this was the first time I had tried changing from 2WD. The video stated that sometimes, you need to let off the fuel pedal so that it can perform the switch.
The next day, I was again in wet conditions so I thought I would try again. I pressed the 4WD auto button and let off the fuel pedal. The light continued to blink, then same error message. I tried it several times...releasing fuel pedal, putting it in neutral, putting it in park at a red light...it would never engage 4WD auto and the warning light would illuminate (it would go off after a period of time, though). Oh...initially a green message light saying 4WD would pop up, then disappear only to be replaced by warning light.
Any thoughts??
Curmudgeon
York, Pennsylvania
2014 1500 Laramie 4x4 QC, True Blue Pearl
My 2014 1500 will switch from 2wd to 4wd in all the different scenarios you posted. I really don't think this is an "operator error" type issue.
Is your 2023 still under warranty? I would take it in.
turkeybird56
Central Texas
Thanks. It is under warranty. I will reach out to the dealer.
OP, with a new ride, surprised U not parked in front of Dealership Glass Front.
If sitting still, transmission in Neutral, have U tried to Hit 4WD button and does it activate, and proper buttons light up, etc? If it does not, insure you do all same again and RECORD to show dealership SA so they see the problem, and U do not get the dreaded: "Cannot Duplicate Excuse".
Not just Auto Button, but also hit 4WD Hi. In neutral, rolling real slow, 4WD Low.
IT does sound like the 4WD actuator(s) are malfunctioning.
Pastor Bob
Pastor Bob
Carthage Mo
Peaky thing called work prevented me from parking at dealership this morning. Already called and have appointment. Good advice regarding recording it. Thanks!
rocket
Licensed Dynacologist
connecticut
was 2006
was a HEMI 5.7
Could be the tipm module. Mine was changed with the actuator. Dealer replaced both. First the actuator same issue was present then the tipm. That did the trick. Once moisture gets into the tipm. It’s just a matter of when and not if it goes.
turkeybird56
Central Texas
But brand new 23 ride. Hmmmmm. No QC in my opinion ne more.
jasonjsla
