5.7 Intake manifold leaking oil, upgrade to 6.4?
16WhiteQC
Mid Hudson valley, NY
So my factory intake manifold is leaking oil at the seem by the pcv (63,000 miles).
A new OE 5.7 manifold is not cheap when compared to doing the 6.4 swap.
Looking into the 6.4 swap I will need the following:
Would do the MMX kit with harness - I think I need to source and EGR plate now though (they no longer include them?)
New air intake - does the 6.4 S&B fit our truck? (I.E trade in the 5.7 on the 6.4 with S&B under the upgrade option)
Catch can no longer works (I am not drilling/tapping 6.4 set up) - I am ok with this
Tight clearance with AC lines and TB - slight bends and should be fine.
5.7 Engine cover no longer fits - just cosmetics
Need revised tune for 6.4 injectors - I think JG changes $100, not an issue.
Am I missing anything?
Everything I read says this is a solid upgrade and since my current manifold is leaking so why not?
Check the bolt torque on the manifold.The bolts holding the manifold on are famous for loosening off,and should be checked at least once a year.
The torque sequence and torque specs are in this thread.
16WhiteQC
16WhiteQC
You dont need the harness, Just extend the wires.
ERG block off plate is dealer item
Get the new Jeep 6.4 manifold its dirt cheap
Plenty of threads on this already with all the answers. https://www.ramforum.com/threads/6-4-intake-manifold-swap.163727/page-13
I have read the threads, don't recall seeing anything about the S&B 6.4 intake fitting the 1500 with the 6.4 manifold swap.
I'll buy the harness vs cutting and extending wires, it's worth the cost to me.
16WhiteQC
16WhiteQC
Bolts were loose, but my leak is the seam, there where it's wet from the looks of it after degreasing everything.
Leaks down the back of the head to the block/bell housing and down.
crackerjack1957
2014 Sport 1500 CC 4x4
Hemi 5.7...65RFE...4.56
Better check MDS solenoids under intake
They are know to leak & push oil out under intake
DILLIGAF
Canada
Never mentioned the S&B 6.4 intake so unsure what you're referring to.
I just tried to save you money getting the Wagoneer intake manifold instead of the truck intake manifold.
So if you saw that thread, why are you asking the same questions that were already answered.... lol...
16WhiteQC
16WhiteQC
It is leaking from the seem higher up on the intake, not from below it as far s I can tell.
(was wet up high)
I mentioned the S&B intake in my original post...
You replied that the 6.4 swap has been covered in many threads already...
I then replied that I don't recall anyone mentioning using the 6.4 S&B intake...I.E. I am trying to find out if that a viable option for an air intake with the 6.4 manifold swap.
I am not sure what you are not understanding, I saw the thread you keep referencing and read it, yet I still had questions so I asked them.
WTF is with this forum anymore!
(was wet up high)
The S&B 6.4 CAI fits a 1500 with the 6.4 intake
