- Sep 25, 2019
- 2,656
- 2,417
- Location
- Rochester, NY
- 2019
- Hemi 5.7
Need a update, many on here posted, let us know and what you found, and that $50 reward was well earned.
no coil packs - Only one coilIf you have no luck with coil packs. I know I’m stretching here but check as many grounds as you can find. Then check your click spring. I had a problem of cutting out for years. Had free extended warranty. They replaced everything. Anyway years later met a electrical engineer from Chevy. Said guys overlook it all the time.
I agree 100%, however my comprehension has gone way down since I turned 63. I have a degree in Electronics Engineering and I am just getting slow. It may even be in the drawings you uploaded, but can you tell me specifically which of the 3 connectors on the PCM has the o2 sensor wiring, and which pins on that connector represent which sensor? Both sensors have 4 wires each, 2 white, 1 gray, and 1 black. Thanks againi would ohms test wires sensor to sensor, then to another sensor then to ECM, in all while no mice have chewed wiring, i wouldn't open the vehicle harness, just perform resistance checks, as for 2 o2 sensors to fail with same failure, IMO they would share a signal , ex. ground. because there are 2 individual signals to ecm. i apologize if im confusing, in my head its clear lol. sent you a IM
forgot to mention, all sensors share the same ground supply from ecm(in previous picture)so one wire gets split at numerous points(inside the harness)
If you have no luck with coil packs. I know I’m stretching here but check as many grounds as you can find. Then check your clock spring. I had a problem of cutting out for years. Had free extended warranty. They replaced everything. Anyway years later met a electrical engineer from Chevy. Said guys overlook it all the time.
