Remington99
Been fighting a demon on my 06 Cummins. Last fall had lights come on and off figured it was WSS. Had code checked for left front WSS circuit. Replaced with new sensor, after that light continuously was on. Had someone ohm out sensor everything checks out. Turns out to be a bad ground wire to sensor. .42v at the plug as well as at the abs module. Attempted to run a jumper from neg battery to ground on sensor wire to get proper voltage and lights still don’t go out. Curious if anyone has any insight. Understand I’ll likely be chasing the ground wire through the harness to find a broken wire but why wouldn’t the lights go out with the jumper?
