ABS module replaced and front sway bar question
bubba5xx
Army
Missouri
I found a ABS module at a local junk yard for $200.00 for my 2014 1500. Installed and performed ABS and brake system bleed and no more idiot lights on dash. Cheap fix for a part that has been on back order for so long.
I am also replacing the front sway bar links and the sway bar looks up side down? Is there a correct way to install?
Thanks for your help!
