Rustypipes12
- Jun 16, 2022
- 39
- 8
- Location
- Buffalo, NY 14207
- 2008
- 5.7 hemi
'09 TRX4 just replaced rear calipers, rotors, and pads all around. ABS, traction control, and 4wd servo warning lights had all started flashing. After the brake job lights went out for about 100 miles, then returned. My scanner showed "right front sensor" so I changed that and cleared the code. So far no lights. I guess I'll find out today when I take 125 trip to my cabin. I've never changed a wheel sensor before and I'm wondering if they are supposed to have grease on them? the hole wasn't packed with grease just some and the sensor looked pretty bad. Should I have filled the hole with grease before installing the new sensor? I took half a dozen cotton swabs and cleaned out the hole before installing the new sensor. Now I'm wondering if I should have done that,
