AFE shorty headers, the answer to manifold leaks!
Nick@GotExhaust
Preferred Vendor
SC
So the dreaded manifold leak so many RAM owners face is due to the OEM manifolds warping and then snapping the manifold bolts off in the heads. Even if you replace them with new manifolds the issue will happen again! So if you dont want to go to long tube headers the other option is shorty headers. AFE shorty headers are a great option as they offer a 3/8" steel flange that will NOT warp. Also they flow better than the stock manifolds so you will pick up some extra power too.
Unleash more torque and horsepower with this Twisted Steel Header for your RAM 1500 HEMI. Optimized, 1-5/8" mandrel bent, 304 stainless-steel tubing improves exhaust flow for quicker throttle response and overall performance.
Performance Gains:
In-house dyno testing produced gains of +37 horsepower and +58 lbs. x ft. of torque.
1-5/8" 304 Stainless Steel Tubing:
Mandrel bent, 1-5/8" 16-gauge 304 stainless steel tubing construction for unrestrictive flow resulting in more aggressive throttle response and increased passing power.
MIG Welded:
100% MIG welded by certified craftsmen provides the strongest welds for long lasting strength and durability.
4-to-1 Mitered Merge Collectors:
Designed with true 4-to-1 mitered merge collectors to eliminate flow-block turbulence created by formed collectors.
Heavy Duty Flanges:
3/8" thick, 1-piece flanges prevent warpage to ensure a leak-free seal over the life of the vehicle. Includes quality gaskets and hardware.
Factory Mounting Locations:
These headers retain your stock catalytic converters and are a direct bolt-on installation which requires no cutting or drilling to provide a hassle-free installation.
Contact me for a quote and availability
Nick@GotExhaust
Nick@GotExhaust
Preferred Vendor
SC
Message me for a quote
Nick@GotExhaust
Nick@GotExhaust
Preferred Vendor
SC
After filling a couple back orders we have 5 sets in stock right now. Come and get em!
Nick@GotExhaust
Nick@GotExhaust
Preferred Vendor
SC
contact us for a quote
Nick@GotExhaust
Nick@GotExhaust
Preferred Vendor
SC
Message me for more info or a quote
Hydrasport23
Mississippi
AFE is saying that their shorty headers can make almost 60 HP around 3300 RPM?
That sounds little high for a stock tuned hemi.
Nick@GotExhaust
Nick@GotExhaust
Preferred Vendor
SC
4th gen 1500 shorties back IN stock!
Nick@GotExhaust
Nick@GotExhaust
Preferred Vendor
SC
IN stock, message me for a quote
