rpr
- Joined
- Mar 29, 2014
- Posts
- 305
- Reaction score
- 62
- Location
- GA
- Ram Year
- 2014 Ram Limited
- Engine
- Hemi 5.7
So after a lot of research it appears only Chrysler and Monroe offer a direct replacement for the OEM rear shock on the air ride trucks. Fox, Bilstein, and Rancho do not list any shocks as being compatible with the air ride suspension. However, I want something that performs better than the Chrysler and Monroe offerings so I manually tried to match something up. This is what I came up with.
The OEM shock is:
- 23.44” extended
- 16.44” compressed
- LS43 mounts top and bottom
The closest match out there is the Rancho RS9000XL RS999262:
- 23.83” extended
- 15.28” compressed
- LS47 mounts top and bottom
The two primary issues are not overextending the air bags and not bottoming out the shock. The Rancho will not bottom out as it has a smaller compressed length than the OEM shock. The Rancho shock will allow the air bags to expand approx. 3/8” more than the OEM shock based on the published specs though. However, if I pull on the fully extended OEM shock it actually expands beyond the 23.44 published spec and then retracts back when I let go. So since the OEM shock has some give and it’s apparently designed to overextend a bit, the extended length of the two shocks are essentially identical.
Based on the above, I see no issues with the fully compressed and fully extended lengths of the Rancho RS999262 for the air ride trucks.
However, the mounts on the Ranch shocks are LS47 which are slightly different than the LS43 mounts on the OEM shocks. This translates to the bushing on the Rancho being 0.2875 mm wider. This is so slight I don’t think it will be a problem. Based on how the OEM shocks came out of the mounts (easy) I’m sure the 1/4 mm wider bushing on the Rancho will fit fine in the mount without any need for prying.
The other difference is the inner diameter of the sleeve on the Rancho is 1/16” larger than the sleeve on the OEM shock. That doesn’t sound like much and it also arguably wouldn’t be a problem after properly torquing it but that worries me a bit more.
So I’m thinking the best option would be to replace the OEM 14mm bolt (which is designed for the OEM LS43 mount) with a slightly larger 9/16” bolt (which is designed for the Rancho’s LS47 sleeve). Hopefully the slightly larger 9/16” bolt will slide through the OEM shock mount holes on the frame/axle without any need to enlarge them, but a 1/16” difference is fairly significant. I highly prefer not to enlarge the factory shock mount holes so I may see if a 9/16” bolt will fit before purchasing the shocks.
There’s such a slight difference between the OEM LS43 mounts and the Rancho LS47 mounts that I probably don’t need to change anything and can reuse the 14mm OEM bolts. But before I leap into this I figured I would post the Rancho shock specs and model number here as there are several posters who have wanted to change their OEM shocks on their air ride trucks and felt they had no aftermarket options, and to see if anyone had any thoughts on any of this.
The OEM shock is:
- 23.44” extended
- 16.44” compressed
- 23.83” extended
- 15.28” compressed
