AlfaOBD
4eyedconekiller
North MS
EcoDiesel
A little walk through of how to program FOBIKs
First turn you truck on to accessory.(I always do this to connect to the RF Hub)
Select Radio frequency hub(RFH)
In the drop down select Radio frequency hub(this is the only option to select here)
Connect to the RF Hub
Once you’re connected. Locate the Car with the hood up on the bottom right hand corner. Click on it
Click on the drop down menu. Almost all the way at the bottom select - Program Ignition FOBIKs Baseline system
At this point turn your key to the Lock Position(turn the truck off) and remove the key from the ignition
Place the FOBIK(Key) you’re wanting to program in the ignition and leave it in the off position
Enter you 4 digit pin provided by your local dealership
Click Start. Your screen should look something like this!
Once the process is complete you will see Procesure complete in blue. Please note the above dialogue box will say “FOBIK successfully paired” I think lol
If a key is already Paired to your truck. You will get the Failure error. “Failure FOBIK already learned”
Now start you truck up to make sure it was successfully paired!
2018 Black Pearl Ram 1500
LED Tail Lights, Black Quad Halogens with LED conversion, LED Black 3rd Break Light, Blacked Out Emblems, Rims & Grill, 8.4 UAQ conversion!
Followed this procedure with dealer generated key. No bueno. I have one good key, and a new blank. Any suggestions, y'all?
Ricks Ram
What message are you getting once you press (program Key)
dracman
canada
2017 black out edition
will alpha work on my dads 2011 sport.i seen something but cant find it now
jawzs2
South Jersey
RipTheDuke
US
Cummins 6.7
It’s pretty rare that you see guys using HIDs for high beams, just because of the warmup time would make the flash to pass feature useless, and most only use them for minutes at a time.
I run HID on my ram from headlight revolution and they do not have a warm up.
HUGE difference. Went with the HID in projector headlamps instead of the LED because of light pattern output. Headlights, fog lamps and high beams. Photo is headlights and fog lamps only. Never mind on the photos. Won’t let me show because “advertising”...
78Staff
US Navy Veteran
NE Florida
So I tried to search... this thread has become mammoth lol...
For swapping standard tailights over to LED tails - do we still need a harness or can AlfaODB change settings negating the need for an adapter? Or do we still need it for making the connections?
https://shop.retroshop.us/ProductDetails.asp?ProductCode=13.TL.Adapt
I recall reading something about using Alfa to change light settings to LED or HID, etc, but didn't pay close attention as I wasn't planning on any changes. Now trying to search for it is painful lol.
1500ram12
5.9L Cummins
if you are going to switch to oem led's you'll still need the adapter just not the resistors. Aftermarket will be more plug and play.
You'll still need alphaobd to change the tail lights settings to led's
2018 2500 6.4L
4eyedconekiller
North MS
EcoDiesel
clifford15
CTD
Yep. Went and got it from my reluctant dealer
Failed. Security Access Denied.
For key programming problems please state (at a minimum) type of key, version/platform of Alfa and type of OBD dongle. There were versions of Alfa that broke key programming but one would expect them to be purged by now. Or the glitch may have be reintroduced.
Hopefully you get this figured out!
4eyedconekiller
North MS
EcoDiesel
clifford15
CTD
4e..., current versions:Android 2.1.6.8, Windows 2.0.8.0
If you are using this on a 2014 as listed in your sig then no bypass cable is required.
Also tip key uses low line (or something like that) programming.
do you autocross your EcoD?
crzyamerican
3.0 Ecodiesel
My bad. A signature in a response through me off. Thanks for the correction
pakvalet01
