AlfaOBD
Black-Wolf
North Carolina
So what Model, function, and Control unit (the first three drop downs in Alpha) are you finding the "Police Lights" setting? I'm asking because I can't find it. I went through the restraint system wiring diagrams (see attached - you'll need a .pdf reader) and there's no reason that that setting (assuming it's even related to the airbag - which it shouldn't be at all unless it disables the airbag when the setting is on assuming that the officer driving is in a chase with lights on - this would presume that he's going to do a PIT maneuver on another vehicle and you definitely don't want an airbag deployment in that case!)
  • RESTRAINT-SYSTEMS.pdf
PA Ram
Quakertown, PA
You might actually have an airbag issue... IDK, but when it comes to Airbags, they are one of just two things I won't attempt to fix on my own (the other being mount/balance tires - more because I don't have the tools rather than not being able to). Since this was once a police vehicle, it is possible they disabled the airbags or that the airbags were deployed at some point - that makes everything suspect with regards to the airbag behavior. I'd take it to a good mechanic, or the dealer. Check on airbag recalls too - though I don't think dodge/ram was affected by the faulty airbag thing a few years ago, a lot of vehicles were!
This makes sense. Police cars I'm sure could disable airbags while performing pit maneuvers and other similar things. Maybe the airbag is disconnected. I had to pull mine to add steering wheel audio controls and there are plugs on the airbag module. Anything's possible. Like you said, best to get it to someone that knows more.
diymirage
I will try to read that on the computer tomorrow
This is how I found the "police lights' setting
BCM
2015 charger
Car configuration change
Vehconfig 3: police lighting feature
(The reason I want it off, is because part of that setting disables the auto unlock on the rear doors)
I checked the codes in the BCM and found nothing, I had to go into the airbag module to find it, and I included the screenshots of it
Black-Wolf
North Carolina
Something else occurs to me: A bit of a long shot, but did you verify that the child safety locks are manually set to not be engaged. There's a small electro/mechanical switch, usually in the front of each passenger door - you may have to look to find it. If it's in the wrong position, the doors typically won't unlock at all...
diymirage
One of the first things I checked
With the police mode on, I could unlock the rear doors with the switch on both front doors, as well as with the keyfob
What I could NOT do, is drive the car, put it in park, open the driver's side door and have all the rear doors unlock at the same time
That is part of the "police lights" line
(Dont ask why)
The other thing is does is allow me to run total black out mode
No lights, anywhere
Jimmy07
And...my airbag light is back on
This is what I'm trying to accomplish l, my wife's winter beater is a 2015 pursuit charger
As such, the rear door do not unlock when you open the front door because of a line "police lights" (YES/no)
The only change I made was switch over to "police lights" (yes/NO)
Now I get this code
I guess that means I need to change a line somewhere...but where ?
You need to swap out the ORC module for the non-police group module part number.
diymirage
Would I be able to just reset the ORC?
There is a line for that in alfaOBD but it says you should only do it when replacing it...kinda like the warning you get when you refresh the RF hub for new keys
BrewskyAZ
Phoenix, AZ
Has anyone purchased an Amazon fob, used AlfaOBD to add that new fob and have the proximity work? If so, which fob did you purchase?
Thanks in advance!
Atcer2018
Virginia
Thanks in advance!
Yes, from a company, KeylessOption on Amazon. They have an Amazon store if you search for them. I purchased a two pack for my 2018 and they both programmed perfectly with AlfaOBD. All functions work including remote start and proximity handles.
BrewskyAZ
Phoenix, AZ
That was the first I tried and the proximity didn’t work. To make sure it was the one I bought, would you, by chance, have a link?
Jimmy07
Other than just adding them in AlfaOBD, did you have to do anything else? Did you remove the old fobs from the hub? I am wondering if proximity will only work on the first two fobs registered.. just a thought.
*Edit: Never mind- misread what you’re asking
Mpgrimm2
Preferred Vendor
SC
2022 Ram 1500 (5th Gen)
5.7L
No personal experience to verify it, but there was a post or two from someone in the remote start thread (can't recall who/which thread) that these ...
Key Fobs from Amazon reported to work/program with AlfaOBD.
Aupoko GQ4-53T 4 Buttons Keyless Entry Fob
References/info that may help (Not Guaranteed)
RamForum - Alphaobd remote start thread
Ramforum - How to add remote start to 2017 Ram
Dean2
Near Edmonton
After market FOBS are REALLY hit or miss, even from the same supplier. I got tired of wasting my time with them and went to buying only OEM FOBs. If you do a bit of research you find the aftermarket FOBs have a 70% initial failure to connect or work, and of the ones that actually connect, most kack after 2 or 3 years.
To me, the time I was wasting was way more valuable than the little I saved on the FOBs. If you are having them setup by the dealer or a locksmith, for sure they are a bad idea because you pay for their setup time whether it works or not.
Atcer2018
Virginia
I’m not a good source to answer your question. In my case I purchased a BigHorn model which does not come with proximity handles or keyless and go. I added the keyless and go feature with push button start myself using the directions on this forum. I replaced my RF Hub and programmed everything from scratch. I will say that I have four fobs programmed to the truck, two Ram branded and two aftermarket. They all work so more than two fobs can be programmed.
RebelRancor
Colorado
Does anyone know what vehicle package in the my 2020 bcm does? Its 1-7 1 is "essence/base" 2 is "sport" and 3 is "luxury" wondering if these may be the key to unlocking additional evic load screens?
tbowers391
Man, there is SO MUCH information in this Alfa OBD on here and on the web in general. Which is awesome thank you all.
But I’m having trouble sifting through all the noise to find out just what would be the minimum age of the android tablet I need for this to work? Like 2011 and newer or what?
Trying to find a cheapy on marketplace or online.
Thanks!
Dean2
Near Edmonton
Thanks!
Go to the Alpha website. If has the most recent Andrroid versions it will work with. They change at some upgrades. They also have alink to the help doc that has more detail yet.
