That's because your truck has CAN (first year in Rams for it) but even then is limited.jscan says it works for 2006, you could try the free version see if it will do what you need.
Your options on vehicles of that age are heavily dependant on what it is you are trying to do. They were controlled completely different than the vehicles of today.So Alpha OBD works on newer trucks, but not my 04. Is there anything like it for the older trucks like mine? Anyone know?
Playing with settings just to see what happens is a very bad idea. There are three recent posts of guys doing serious damage they can't fix from that kind of exploring in alphaobd.I just wanted to play with it. Thanks for the replies
The best you can do is get a DRBIII or compatible scanner and you can do stuff like change some user settings (light duration on shut off, horn honk, etc) and use it for diagnostics and/or a quick learn when you eventually have to replace your RFE.I just wanted to play with it. Thanks for the replies
