Aluminum tailgate
CrispyBacon
Did you know?
Found out with my magnetic work light. The bed is steel, but the tailgate is all aluminum.
DanAR
Arkansas
Huh, guess I need to check out mine. Probably nice if you need to remove it for some reason.
Badger 13
North Idaho
2013 Dodge Ram 1500
Sorry if I missed that this was the 5th gen forum, but the RP's vehicle is listed as a 4th gen...
mrack
and no rusting
The aluminum not rusting thing is a gimmick. It doesn’t technically rust, but it corrodes just the same. Just look at the aluminum hoods on older 4th gens, large majority of them have a lot of bubbling corrosion around the grill.
mikeru
Super Moderator
Super Moderator
The Palouse
2020 Limited
Hemi 5.7L non-Etorque
That's true, but his avatar shows a 5th gen. Either way, @CrispyBacon update your truck info in your Account Details please. Either that or be more specific about your truck when making claims about it. :D
barr0208
winnipeg manitoba
2019 ram 1500 sport long bed
5.7 3.92 4x4 ruby red
that means ford trucks will really look bad when the corrosion starts
DanAR
Arkansas
I’ve owned several Mustang GTs with the aluminum hood and at least up until I got rid of the last one a couple years ago, they were still having random trouble with corrosion bubbling around the edges. Hopefully RAM has got it figured out by now.
CrispyBacon
CrispyBacon
None of that stuff even shows up on mobile!
I'll update my truck details when your wife updates her relationship status to "it's complicated"
mikeru
Super Moderator
Super Moderator
The Palouse
2020 Limited
It's not there for you to see, it's there for others. Who knows what percentage of members use mobile? But suit yourself.
