Black Smoke (rolling coal)
John Aucoin
US
2007 2500 TRX 4wd,6.7ltr 138k miles, noticed that when driving under light excelleration I have black smoke out of exhaust. Have muffler, but no Cat or ex parti filter, delete kit installed, min hp gain. Engine feels like lost power. And now the coal roll. Only think that has been worked on lately, is AC compressor, and cond coil, accumulate/filter, hoses, belts, pullies, belt, expansion tube, changed, don't think this has anything to do with it. Any one have this issue? No codes. Any suggestions on what to check, or what could have gone bad. It is like running rich. BANKS AIR filter is clean,. What would you suggest I check
06 Dodge
Forest Grove, Oregon
6.7L CTD
Leaking or sticking injector(s) MAF sensor, it may not hurt to run a good shot of injector cleaner along with a good work out and if that fails it may be shop time to investigate. Did did this happen after a resent fuel purchase a different fuel stop?
J
John Aucoin
US
Yes, started after Fill up, at a station I have used before, but yes, soon after Fill up. All of those good Ideas, plan to add some sea foam and go blow it out. Thanks
06 Dodge
6.7L CTD
OMG No do not use Sea Foam that stuff is mostly alcohol, Alcohol is not good for you fuel system, use something like Power Service in the silver bottle, Howes meaner cleaner, Opti-lube single diesel fuel system/injector cleaner or one of the many other injector cleaners that does not contain alcohol...
J
John Aucoin
US
Gonna go grab that, hope I did not mess up, already added it, Damn it! thanks!
06 Dodge
6.7L CTD
One small dose should not hurt much, just remember to use quality additives for diesel fuel and Seafoam is not one of them, when it doubt ask, the only stupid question is the one not asked..
OLEJOE
N. La
6.7 CTD
Check all of your boost hoses and connections. Sounds like you are loosing turbo boost somewhere.
