Ceramic coating in cold
CanRebel
Toronto
Question if anyone is aware. It does matter if you apply it in cold?
Purchased some Adam's 1 year ceramic coating. Their cheaper one few weeks back.
Currently only place to do it is outside, and it's around 0-5c. Should I wait till spring to do it?
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
Um, why not ask Adamspolishes .
I'd think they would know their product and they are a ramforum member.
KKBB
Oakland Ia
I asked Adam's that same question...their response was it is ok to apply it at any temperature.
brunzca
St Johns, Fl
Hemi 5.7 (non-Etorque)
If the instructions don't specifically say not to apply it above a certain temp, it should be OK. I'm not familiar with this product though. If it's a true ceramic coating (i.e. not a spray on), it will likely take longer to flash in that low of a temp, so be prepared for that.
Treburkulosis
Your High End Detailer
Haslet, TX
Yes any temp is fine. I find it quicker to do it when it is 50-60* It seems to take longer in below 55* temps to rainbow.
Riverside California
2018 2wd
HEMI 5.7 Revolution 4.88s
Just make sure it is not too humid or the moisture from the cold is not bad ... best way to see if it's ok to apply a ceramic coating is to spray a panel with an IPA solution ... if it takes a long time to dry after you apply it on the panel with a microfiber towel then it is not ok to apply a ceramic coating ....
CanRebel
CanRebel
Toronto
Besides the first post. Thanks all for the response.
Thinking I'm going wait until spring to do my truck.
Going practice on one of cars first.
I did check with Adams before posting. But wanted to see if anyone else had real experience.
Raining/Snow/Cold, might as well wait.
retired
montana
What did adams say? thanks.
CanRebel
CanRebel
Toronto
They responded to my email, and said same as KKBB said above.
Any temp was fine. But not when snowing. wasn't recommended to do outside if it was windy.
