Richard C
I recently bought a 2020 Dodge Ram 1500 Limited with air suspension. It came standard with 22-inch wheels. I want to switch to 20-inch wheels, but the dealer tells me that's quite involved -- if they do the work I'd have to replace not only the wheels, but probably also the hubs and bearings, knuckles, and front and rear axle shafts, which apparently are all different in the 22s because of the bolt pattern. However, a local tire place says they can make the wheel switch without all this work. I'd like to go with the local tire place, which is far less expensive, but don't want to damage the truck or create an unforeseen problem. Can anyone advise?
