Cluster light help needed
bigd197363301
St Charles MO
I have a 2004 Ram 1500 5.7. Everything was working fine until I pushed the trip set odometer button. I now have no odometer lights, shifter indicator lights, check engine (all indicator lights on the left side), or turn signal indicators. The turn signals work outside, but not on the cluster. Any suggestions are greatly appreciated!!!
HarryS
Clovis NM
You might try removing the cluster and reseating the connector on the back.
B
bigd197363301
St Charles MO
I removed the cluster and replaced all of the bulbs and did ensure that I seated the connectors when hooking it back up.
jws123
nj
you could send it out to get fixed many companies that do it for old clusters I have done it many times for my older trucks. However you can go on ebay and find a cluster with close miles and plug and play usually like $100.
