Confused by P0524 Engine Code
Clarks Customs
Myrtle Beach, SC
Hey guys, I have an interesting issue and am working on how to diagnose the issue. Any help would be appreciated!
I have a 2011 Ram 1500 Laramie Longhorn, 4x4 , 5.7 Hemi. I just installed a new 5.7 engine due to a trashed cam and 1 lifter.
We installed an HV SRT oil pump (68195993AD) to help with low RPM lubrication. The HOT idle (600 RPM) oil pressure is 38 psi (260 kPa) and 78 psi (540 kPa) @ 2000 RPM. The oil pressure-sending unit was replaced with a new Mopar unit (5149062AB).
For some reason, I keep getting the P0524 engine code (Low Oil Pressure). We have reset the code but it keeps reappearing. No other codes appear.
I am using the AlpaOBD software to read the codes and engine performance. Based on the numbers we are getting for oil pressure, a P0524 Code does not make any sense. Has anyone run across this before? What do you guys think?
About the 23 minute mark is where he starts getting into using a set of resistors to cure the issue
The other option is to run the bypass spring from you're original pump,but now that the pump is installed,that's probably not really feasable.
