Crazy clutch story
Jer56
Utah
Have had recent problems with my 99 Ram standard transmission not wanting to go into gear especially after warmed
Up. I took the old girl to a trusted transmission shop and they said I needed a clutch overhaul. $2300.00!!
I can’t do the heavy work anymore due to both shoulders replaced after 40 years in the construction trades.Being on disability and a fixed income it wasn’t going to happen.
I was looking at the Dodge factory carpet behind the clutch pedal and noticed a deep indentation where the backside of the pedal has been stopping. I started wondering if a little extra room for pedal travel might help.
I decided to cut out the carpet and the rubber backing pad behind it.
There was at least an 80 percent improvement in the shifting!
My question is has anyone out there seen anything like this? I feel like I
have maybe bought myself a little bit of time at best?
Thanks in advance for any thoughts!
ibike
Tennessee
Not familiar with the older Ram clutch release system, but if it’s hydraulic you could be low on fluid, need a new master or *****, or have a bit of air in the system.
J
Jer56
Utah
Yeah hydraulics was my first suspect but my transmission shop said hydraulics were fine
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
when it comes to standard transmissions
the throw out bearing comes to mind, it could need adjustment
do not adjust to the point of going past Center
J
Jer56
Utah
Wow I didn’t know the throw out bearing was adjustable.
I will look into that.
Thanks
