- Aug 2, 2018
- 19,193
- 43,871
- Location
- Central Texas
- 2019 Bighorn, 4 X 4, 3.21 rear, Bright Flame Red Pearl Coat, Mopar tonneau cover,Westin Bed rug
- Hemi 5.7
IF U just pulling a small trailer on 4 pin, most of the electronic gizmo's built into the truck for towing will not be enabled. THEY R really made for a 7 pin hookup detecting electric brake setup. I assume, hate to do that, that trailer sway will work as intended, but not sure. But since U R on a 4 pin, there will be no trailer braking, since not engaged on a 4 pin, no electrics. U are strictly talking the "truck" doing all the stopping/braking alas push/pull of the hitch setup, unless say yer lil trailer has a hydraulic brake system built in, like a lot of the boat trailers do.I have not had time to try to get into u-connect yet. I’ll try to today. I was using the 4 pin trailer hookup. It’s a small utility trailer and I didn’t have the tow setting activated. The front and rear park sensors were turned off.
Thanks
ADDED: U connect take U about 22 seconds to check ref E Brake. Hit setup, scroll to "BRAKES", open that screen and observe auto park brake setup and whether or not enabled (box checked or not).
