- Apr 28, 2012
- 23,392
- 45,351
- 2010 Hemi Reg Cab 4x4
- Hemi
So we have had a couple guys running biotech so we should start seeing some results, and hopefully this thread will encourage people with hemi tick to try other lubrication strategies. For those that follow, Lubegard Biotech is similar science to Redline, and as we have seen it can be an effective answer, also backs up reviews at amazon. Running this is like 1/2 the price of redline, so if it has similar success rates this ends any argument of why not use this inexpensive option that dresses up any random group 3 motor oil. With the modern engines oils become more sparce, this may be something you want to add to every non di turbo engine you own. I know @Hemi395 put it in his work truck, killed about 80% of his tick in that.
Now, I am leaving that you can change your answer, to keep up with accurate info and change answer as needed. Consider this, since lubegard is similar science to redline, keep in mind even if it isn't effective at first, it can take time for the plating effect of the formula, JUST LIKE REDLINE. So change those votes as needed to give a proper snapshot of the effectiveness of this product. I don't know you should change the vote if the truck sat for a long period like over two weeks, I'm not sure there is a lubrication answer for those engines, but how you report that is up to you. Thanks Burla
