Giorgio_Rampa
This is done on a 2022 RAM 1500 Classic - Warlock
The regular size bulbs will NOT work with the low or high beam.
Lasfit did not specify which bulb would work on a Warlock, but I can confirm that the MINI will work on the low beam, I cannot confirm if the mini will work on the high beam.
Here's a tutorial that I put together to help do the swap.
www.youtube.com
![www.youtube.com](/proxy.php?image=https%3A%2F%2Fi.ytimg.com%2Fvi%2F5W1k4OY_9-A%2Fmaxresdefault.jpg&hash=d92778ad10544fa979e7c2760dadac45&return_error=1)
RAM 1500 Warlock - LED head lamp swap - Lasfit - WHAT NOT TO DO!
This is done on a 2022 RAM 1500 Classic - WarlockThe regular size bulbs will NOT work with the low or high beam.@lasfitvehiclelife did not specify which bulb...
![www.youtube.com](/proxy.php?image=https%3A%2F%2Fwww.youtube.com%2Fs%2Fdesktop%2F4610dd25%2Fimg%2Ffavicon_32x32.png&hash=1e068c12bd940440541971db44990e86&return_error=1)
