NY Andrew
I have a motorcycle and just got off the phone with a super smart ECU flash guy.
Somehow got sidetracked and started talking about the Hemi and he said something I haven't heard or read before, so figured I'll post here see what you guys think on the subject.
He said how when you first bought the vehicle brand new it almost seemed a bit more powerful/louder/responsive. Then over time due to EPA regulations and aging, it begins to seem more bogged down.
His recommendation to sort of refresh/resolve this after every 50 starts, is to pull whichever the fuse is labeled for Chrysler (ECU/ECM/PCM) with the vehicle off, wait 10-30 seconds, then put it back in.
Anyone ever heard of this or tried this? And know which fuse it is (I haven't popped the hood yet)?
I don't drive the vehicle that much so I'm thinking I'll do this once a year at my yearly oil change if this indeed is a good thing and doesn't require having to reprogram anything in the cab.
He also had an interesting perspective on non-ethanol fuel (which is all I use in my vehicles).
Motorcycles have a more narrow-band fuel-mapping and he recommended to use fuel with ethanol (also what the flashed ECU was mapped for) vs automobiles which have a more wide-band fuel-mapping and can handle non-ethanol better; but like he said non-ethanol seems to sit in the gas station tanks longer and generally would be best if the vehicle sits like two years. I've always used non-ethanol mainly because it doesn't retain as much moisture.
Thinking about making the switch from non-ethanol to ethanol mixed for the bike now after this flash and his recommendation, but I guess the Hemi will still be okay with non-ethanol as it's mapped for a wider range and the fuse pull may help as well.
