Error code p0700. At dead end need help!
rico13
Vancouver, WA
Hello! This is my first post. I have a 2005 dodge ram 1500 4.7l. She has 215k on her. She's ugly but she gets the job done. My problem is that she throwing a code of p0700 and a secondary code of p0740. What I can find is that it's the transmission clutch or a sensor. But the thing is that she runs strongs, shifts into every gear perfectly with no problems. I can delete the code but after driving for a hour or going highway speeds. The check engine light comes on. I did replace the output speed sensor and that never did fix it. I know when it gets cold that the oil pressure sensor likes to act up. I have a new one but I'm going to replace it soon. Dose anyone know what is going on?? Or can give me some advice so I'm able to fix it? I don't think it's the transmission. Could it be a sensor??
jws123
nj
If i remember correctly from my old 2005 those 2 codes meant the torque converter was starting to go bad I remember replacing the valbe body never made a diff. With the mileage you have on it make sure your fluid level is good and keep driving it until it doesnt.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
