CalDad14
- Jun 9, 2021
- 63
- 54
- Location
- Calgary, Alberta, Canada
- 2017 Ram 1500 Crew Cab, 4x4, 6-speed, short bed, 392gears
- 5.7
So I feel like I'm hearing a constant humming(whirring, pump motor running, poss. fan spinning, but not rad. fan) from the front of the radiator on the driver side.....
It's not the radiator fan, it's not the A.C., not the defroster.
In regards to the "1st start of the day";
I know what it sounds like when it's really cold or really hot. It's not that.
2017 Ram 1500, 5.7, 6-speed, 392gears. 4×4, approx. 37500kms.
I have been noticing my coolant temp fluctuating from 92°C(197°F), jumps to 101°C(213°C) then is suddenly/very quickly back to 92°C(197°F). It will do that not only driving, but at idle.
When this happens, the oil temp can(not every time), also fluctuate w/the coolant temp. 93°C(199°F) - 99°C(210°F) - 93°C(199°F).
After five days of this, I started to get a "low oil pressure" message flash(4 a split sec.) on the 1st start up of the day and only the 1st start of the day. Message immediately goes away, oil pressure gauge is right where it usually is upon fire up. Running RP 5-20, oil looks good, level is nearly perfect. Upper part of the cross hatch area on the dip stick. I got the message 5 consecutive days in a row. Didn't get it this morning.
No check engine light. It's kind of frustrating, cause the truck is running really good. But I still feel like somthing just isn't right.
Any ideas are welcomed. Thanks guys.
