Ground location for radio
mjsmith7997
Alabama
MY radio in my 2014 ram 1500 crew cab just went black a few weeks ago. I bought a new radio and hooked it up. It didnt come on right away. I had to wiggle the wires to get it to come on.where is the grounding location for the radio?
SitKneelBend
St. Louis
3.6 Pentastar
Use this site and filter on "Radio C1" to get a pinout of your radio harness.
M
mjsmith7997
Alabama
I get that but the ground wire in the harness has to be grounded to the vehicle somewhere. I need to know where it is.
SitKneelBend
St. Louis
3.6 Pentastar
That site gives you every wire and ground on your vehicle and the associated harness (unfortunately not in exploded diagram form). If you suspect a ground issue, inspecting/improving/adding grounds might be your best bet. If I had to guess, the bare metal wire in the harness is ground and if you wanted to improve it there is a factory ground location under the steering wheel are.
