Quadrunnerjake
So im having some issues with the stock headlight wiring. im in the middle of retrofitting projectors and ran into issues.
2 lamp system.
Before i tested my harness:
pin 1 is R/O and is hot when vehicle is off and when low beams are on, Ground when hi beam is on
Pin 2 V/W is ground only when low beam active
pin 3(V/R) is hot only when hi beams are on
After building harness it didnt work so i removed and tested again and got:
Pin 1 hot when vehicle is off and when low beams are on, Ground when hi beam is on
Pin 2 ground only when low beam active
Pin 3 always hot
how should my 9004 plug test without lamps in them?
2 lamp system.
Pin 3 always hot
