goodoldguy
I looked and didnot see what i was looking for Thanks for any help OLD Guy Here so be patient
2014 Ram 2wd 68RFE Trans Trans serviced, Valve body changed and new solenoid pack
so here is the issue . when i start truck ( Its a 6.7 ) runs fine I have it in Park it shows reverse ( when its in park) now when i shift to Drive Than the display is normal,, The park assist says the truck is in reverse and the park assist light below radio stays on Until i put in Drive.
Also when the selector shows its in reverse when its not The back up light are not on.. when i actually put it in reverse the backup lights work as they should .. I have a Autel 808 Scanner and the AlphaODB No trans codes ?? this is a mystery to me I unplugged the Park assit module removed fuse and disconnected the rear sensers ,It only has rear no front ... NOTE it was doing all this before i did the trans work The Indicator issue is why i did the trans to begin with . sometime you hit the key and it just clicks, than you do again and starts ..
I checked all the fuses ( Non Blown) Please ask all the questions you want , sure i am leaving something out ... OH the Miles are 139K
AT this point It seams like something is wrong with the Park assist system Note i did order 4 new sensers But they checked out fine when tested with AlphaODB Thanks Every one for the Help Old Guy RoyBob
