Jimmy07
- Feb 23, 2017
- 3,257
- 2,917
- 2017
- 6.4 Hemi
Here’s a write up on how to add factory keyless enter n go (push button start) for anyone that wants to do this. My goal was to do this without a dealer visit and entirely with the alfaOBD software, but initially it wasn’t capable of programming the new fob and RF Hub replace. After some back and forth with Alexey (the developer), some debug logs, and a few updates, we finally got it to work. The good thing about adding this feature is, if you’re on a budget, and can’t buy all the parts at once, you can do the install in two separate steps, and have the individual features work as you progressively install the remaining parts. I’ll outline the install in the next few posts based on the order of those individual steps.
To start off with, here’s all the parts you need. I was able to source all of this for about $470 (assuming you already have the alfa software).
Start button switch (‘13-‘18)- 6CK46DX9AC
(2) In cab antennas (‘13-‘18)- 56046958AA
(2) door antennas (‘13-‘18)- 56046957AA
RF Hub (‘17-‘18)- 68319680AD
*NOTE*- It’s possible that some early ‘17 1500s have the older hub. Check your hub part number by connecting the alfa to your RF Hub, then click the battery icon bottom right, and read system ID. If you DON’T have part # 68319677Ax, then follow below.
RF Hub (other years)- 2014-2016 hubs are different than the 17-18s because the 17-18 hubs all support remote start and air suspension, and the 14-16 hubs are all different depending on whether or not you have remote start and/or air suspension. The best thing to do is search auto trader for a truck the same year as yours and the same remote start and air suspension (or not), but with keyless go, and use that VIN so the parts department (or Benny at allmoparparts.com) can get the part number you need. 2013’s are different than the other years, also (I think), so same situation as above.
Front door handles- https://www.moparautopartsdirect.com/v-2017-ram-2500--laramie--6-7l-l6-diesel/body--front-door
Rear door handles- unfortunately, the front keyless entry handles aren’t available for textured black, so for those with four door tradesmans, you’ll have to spring for rear handles, too, if you want everything to match- https://www.moparautopartsdirect.com/v-2017-ram-2500--laramie--6-7l-l6-diesel/body--rear-door
Key fob (also available with air suspension button)- https://www.amazon.com/gp/aw/d/B07D...F8&qid=1548046339&sr=1&pi=AC_SX236_SY340_QL65
