Infinitysurf
Bought my 2019 Ram 1500 DT Laramie new in Sept 2018, I do 100% of my own maintenance/upgrades and intend to keep the truck long term. Currently has 117k and like many others here, I don't like how often the coolant cycles up too 225 not to mention the elevated engine oil temp levels. I KNOW that the "truck was designed this way" but I disagree with the engineers reasoning which has nothing to do with engine durability, don't care about losing a miniscule percentage of fuel efficiency & I want what I want, lol.
To get to the point... I live in the South & have been wanting to install a 180 degree t-stat but can't find specific info on how to remove all the middle shutters on the active grill shutters without breaking something & know without doing that or getting the truck tuned, etc its mostly pointless. I have found videos on how to do it on 4th gen but removing the grill on the 5th gen seems much more involved. From the limited info I have found, to remove the front grille on my 2019 Laramie & get full access to the AGS I would need to remove the fender flares, wheel liners and the painted front/side panels under the headlights in order to remove some grill bolts behind those panels. I would like to leave the top/bottom shutters so I don't have to worry about CEL lights so don't plan to fully remove the AGS anyway. I removed the plastic cover over the radiator & can reach down to the AGS/shutters but everything I have tried seems like I am gonna break the plastic. If I need to remove the grill to get this done I will, but some of the threads seemed to indicate that is not required. Can anyone give me some detailed tips on how to remove shutters without removing the entire front grille or even better direct me to a video?
On side note - I did the trans thermo bypass about 15k miles ago and LOVE how much cooler the trans fluid runs! I installed the PPE trans pan with replaceable filters around 70k miles. Yes, its a PITA to get the fluid level correct each time but have done 3 drain/fills on my transmission so far and will continue to do that every 35k miles - planning to get this truck to 300k miles+. Have been reading threads here for years & have done a lot of mods/upgrades posted by members here. I actually just ordered the materials to mount my oil filter remotely, will be nice not to spill hot oil on myself & the truck every 4k miles!
