Brianjonesphoto
- May 12, 2015
- 14
- 3
- 2015
- 3.0L Turbo Diesel
Hi I've had a HID bulb kit from Retrofitshop installed on my truck with projectors for 10 drama free years. In the last 8 months I've been chasing intermittent issues when one or the other bulb would not ignite. At first I assumed it was the bulbs aging, but new bulbs did not solve the issue.
The Driver's side light is the most common issues it will not light especially if I use remote start. For a while if I turn the headlights off and then back on both would work. Occasionally the passenger side will be out, but drivers side will work. I have no made any changes to the truck prior to this starting.
Here's a list of the troubleshooting steps I've taken.
Verified HID/LED setting in Alfaobd as enabled.
Check all connectors.
Checked ballast resistors for continuity.
Swapped ballast from one side to the other.
Swapped bulbs from one side to the other.
Swapped other known good ballasts and bulbs.
Checked relay harness wiring.
Swapped relays on harness.
Every time I've had the headlights apart I've been able to get them to work consistently. Then a day or 2 later the issue returns. Obviously I have yet to find the root cause
In the last few days I've gotten to the point of having no headlights and a B162A BCM error code. Which is for a short/open to battery + on the left side. I think I've been able to trace the issue to the truck headlight circuit not supplying signal to relay harness.
If I remove the harness relays and jump the output terminals both headlights ignite as they should. I'm really tired of pulling the headlights only to have to do it again. I'm looking for some guidance here. Since it seems to be a signal issue, my next step is to replace the ballast resisters with new canbus encoders and see if that is a solution.
thanks
thanks
