Daviddnv
- Nov 10, 2021
- 41
- 28
- Location
- Orlando/Daytona Beach, FL
- 2022
- Hemi 5.7
The wear was even all around on the OEM tires. Again, I'm not unhappy with the OEM tires or wear. There was an alignment done and re-checked. So I think that is good. I'm not real unhappy with the Toyos either, I just think there is a little too much vibration going on. The Toyos are quite and have good wet traction, both things that were important to me. As plus, they did real well in deep soft sand last weekend.With the tire wear you are describing on the original tires i would go to a good alignment shop and have your alignment checked, should get a alignment anyway with new tires your rear axle may be out slightly causing the wear. If that does not cure the vibration then i would take it back to the tire shop and tell them to fix it and not give up until you get a smooth ride. I have had every thing from mud tires to street tires and their has never been any vibration or balance issues. You may have a tire with a manufacturing defect that they are compensating for with the wheel weights, do you have a tire with excessive weights on it?
Also sounds like you never rotated your tires, you may want to start that at least once a year to prolong the life of your tires.
I think I'll get them re-balanced and rotated in about a month or so. I'll probably have over 5k miles on them by then. There is a new Discount Tire being built right by me. Assuming they will have the Hunter road balancer, as recommend before, I'll have them use that and see how it goes.
