- May 14, 2020
- 416
- 404
- Location
- New Hampshire
- 2019 Tradesman 2500 Snow Chief
- 6.4
So I have been having a few issues with my truck, which I bought new. I know the 1500's have had some similar issues but haven't seen much on the HD's.
1. Hood flapping at highway speeds. I added a bug deflector and made no difference, not that I added it for that reason. I see that there's a TSB for the 1500's doing the same thing.
2. Squeaking over bumps from the driver's front wheel area. I thought it was a suspension issue so I sprayed the moving parts with WD and there was no change. Again, the 1500's have the same issue and there's a couple possible fixes to include a new brake caliper, greasing the slides, or pad shims.
3. I added 2" front spacers to help with holding the V-plow higher. I had a shop install the sacers and I drove to the alignment shop and was told they can't align the truck because I have a bad passenger side hub. Sure enough, there was play and a faint clunk when moving the wheel to check for play. I have stock size tires and only plowed a few times last winter.
I have an appointment at the dealer on Wednesday but this is a little concerning having a bad hub already. Stock size tires and wheels, so no excessive wear from wheel offset. I guess the good news is that it was found now before I hook my camper to it and drive 3600 miles to South Dakota and back in a couple weeks. I thought the steering was a little vague but chalked it up to going from a 1500 to a 2500.
I did notice that while my plow was attached in 4x4, when I turned my wheel past maybe 1/2 to lock, the truck was incredibly rough while turning, like it was binding or bouncing. This would happen on packed snow, so it was not binding on pavement. The last solid axle I drove was a 1990 Jeep Cherokee, so no comparison with the weight of a plow. Hopefully the hub was the cause of that also. Any thoughts? My 1500 was smooth as silk with the HT plow on it, I figured the HD would be fine with the 8'6 XV2 plow.
Thanks!
Thanks!
