OK so I have a 2012 Ram 1500 with 70k miles on it. A few months ago I had what I thought was a dead battery (which is weird because I put in a auto zone gold battery a year before). Turns out it was the battery cable wasn't tight enough, so I tightened it and it fired up no problem.
I don't drive the truck that often and I had a dead battery problem again since then, so I threw a charger on it and it was fine again. Now the other night after watching a movie I come out and bam dead battery again. Luckily there was a tow truck guy just sitting there at the movie theater and he had a jump box. We got it started but driving it home it was acting like it was dying, like if i step on it too hard it would sputter and then look like it was about to die and it would ding and go again. It was really weird but I got it home.
I went and charged it up again today but it just makes a click sound like at the starter and then the dash dies out like a dead battery would do but my charger has a green/red light to let you know the status which was full. Also after it fails to start I can hear one of the relays in the fuse panel clicking a bunch of times then the dash lights up like it found power again like after a minute or so.
My question is where do you guys think this is the starter solenoid maybe a bad ground? But why would it try to die once it's running. A bad alternator? Which would be a likely culprit if it's not charging the battery but why would that stop it starting on a full charge?
Sorry for the long post it's just I'm trying not to buy and replace parts till I find the problem. Lemme know what you guys think I should do next.
