craigjaster
I have a 2017 2500 5.7 non MDS with what I believe to have the cam and lifter failure.
I also have a 2014 1500 5.7 MDS truck that has been totaled, but it has a good engine and transmission in it.
Couple questions for the hive...
Can I swap the engines?
I can take the harness and pcm from the 1500 as well as the 8 speed trans as well.
The 2500 has a column shifter where the 1500 has the dial shifter. Is that an issue? I do have the entire dash harness too.
If this is something that I can do, how much power am I going to lose if any? Any thoughts or opinions are more than welcome. Thanks
