More grip n rip and less peel n squeal
dirtyUPSman
Palatine, IL
I have a 17 Tradesmen that's slightly modified for performance. I keep breaking loose at the light. I'm looking for advice on a wider and or lower profile tire that won't effect the suspension or clearance.
I do know that I will lose "cushion or bounce" on a lower profile tire but I feel it will stick better plus I think it will look nicer. My thought was to go one or maybe two sizes wider and lower ??
Original size tire is 265/70 17s
Any advice is greatly appreciated.
Thanks.
Thanks.
Alot of the lower level trucks,like the Tradesmen don't have a limited slip / posi diff , so changing to a wider tire,might not accomplish as much as you'd like,as it'll still be a 1 wheel peeler :waytogo:
dirtyUPSman
dirtyUPSman
Palatine, IL
It does leave a pair, when I punch it. Other than that, that's usually when the tire grabs is when the semi slip kicks in.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
My Eco-diesel will spin the tire on take off & i am turning right .
If i am going in a straight line, there is no spinning.
It does have the Limited Slip Differential
Curmudgeon
York, Pennsylvania
2014 1500 Laramie 4x4 QC, True Blue Pearl
What can you tell us about your tires, other than just size?
Like brand? Tread? Also, is your truck a regular cab, quad,
crew, etc? Weight over the rear axle might be a factor as well.
My truck is stock, no mods, but the 5.7L is no slouch, imho.
I really don't think my tires are anything special when it comes
to dry traction but they just don't break loose when going straight.
Also, limited slip 3.21 rear, quad cab, 8-speed, and Falken Wildpeak
tires at P275/60R20, typically inflated at 36-39psi.
armyvet25
Lorain, Ohio
Dodge 1969 383ci
ok, first off, are we talking street driving or track?
lower profile tires do not aid in the traction, the exact opposite...see any low profiles on race cars??? Low profiles stiffens the tire less flex and grip prone to spinning. Wider will help.
If for racing, plenty of ways to add rear traction, traction control bars, lower tire psi, 6cyl front springs-allows the front to raise up faster on take off planting more weight to the rear...etc etc
When exactly do your tires break traction??
armyvet25
Lorain, Ohio
Dodge 1969 383ci
Also, most people have a false idea on correct air pressure for their tires he said she said syndrome.
Over inflation will increase tire spin and stiffer ride, under will cause incorrect tire wear, look up and use the "chalk" method to determine correct tire psi for your rig, adjust as necessary for towing. I find most of my trucks never needed more than 28-32psi YMMV
dirtyUPSman
dirtyUPSman
Palatine, IL
I have Wrangler AT/S tires, I'd say they're a little over a year and a half old. As far as the tread goes I would say a little less than normal, where as I like to sometimes punch it and I do leave some rubber behind. LOL. I can squeal em, even if I'm already rolling. The wife HATES that.
I have the regular cab and also the 3.21 rear end with limited slip and the 8-speed trans. I also have a cab on the back with four rims and used tires. These are the rims that I'm looking to put the new tires on. I also keep my tires inflated about 40 PSI.
dirtyUPSman
dirtyUPSman
Palatine, IL
I WISH there was a track by me !!!
I believe the closest track is about 2 hrs away, and from what I read on the feedback sometimes you get to only do anywhere from 3 or 4 to 1 run at $50 a day. I don't know about race cars but I do see lower hight tires on sports cars compared to non-sports cars.
I have given some thoughts to adding a rear traction control bar but I know nothing about them and wld also need to consider a shop to do the work. I live in a condo and we're NOT allowed to work on cars on the lot.
I mostly break loose at the line, even when I try not to but still want to give it a good launch.
Kinda why I want to go w either a wider tire ( not sure about wheel well clearance) and or a lower tire. Any and all advice is greatly appreciated.
My local track is 2.5 hours away,and i still get there ,up till a year or so ago,i was there every week-end.A set of 305/45/17 Mickey Street R's will hook it.
dirtyUPSman
dirtyUPSman
Palatine, IL
I never heard of the chalk method but after reading about it sounds like a good way to determine what is the best psi per tire. With my torque converter I was told I can't tow, which is fine as my 2 man boat fits in the bed with the cab closed. Perfect for getting off work and hitting a lake for fishing.
dirtyUPSman
dirtyUPSman
Palatine, IL
I do want to go to the track but I wld totally be disappointed if I only got one run at 50 bucks. Thanks for the tire size n make info. I great place to start.
armyvet25
Lorain, Ohio
Dodge 1969 383ci
"I do see lower height tires on sports cars compared to non-sports cars."
you're like a dog with a bone refusing to let go, low profile tires on "sport" cars are not for preventing wheel spin but for handling corners, low profile tires combined with greater width prevent tire roll for better high speed turns
dirtyUPSman
dirtyUPSman
Palatine, IL
Thanks for explaining that better. Turns at higher speeds makes me a bit nervous. I have also given some thoughts of lowering the truck but...$$
Do you have a tire size that might be something I should consider looking into ?
1 MEAN66
Waterford NY
Hemi 5.7 VVT-MDS
Is that with traction control enabled or disabled? Get the tires warm. Drive about 20-30 minutes. Disable the trac button, stand on it, after it stops spinning, stop get out walk back and look at the tires print on the road. Is it solid black and the width of the tire? OR just on the edges? - then add air pressure. OR black in the center only- so lower the pressure. Two to 3 lbs.@ a time, then do it again. The best print is the best traction. remember the pressure. There is a lot more to air pressure in tires than just what the door says. Remember it is the air that supports the load and provides handling the tire is just the container. Or add a Detroit Tru-Trac center carrier. If you are going to actually race it a lot. (they are bullet proof). and gear driven so no "clutches" to wear out. But a carrier change is expensive (especially if you cannot do yourself). And really not worth the money if the truck will not be used that way on a "normal" basis.
