g-nut
My 2004 1500 4.7L 2wd feels sluggish, like something is holding it back when accelerating.
In 2006 I had a 2004 1500 4.7L 2wd for a work truck. It drove very well.
About 2 years or so ago I got a smoken deal on a 2004 1500 4.7L 2wd quad cab. It needed a lot of work but it is running and driving good.
* My only issue is the one noted in the thread title. When accelerating, from nearly any speed, if feels like something is holding it back. Like I have another truck on a trailer behind me.
* I've serviced the motor. Oil changes. Recently changed timing chains. Replaced all of the vacuum lines and rubber hoses. Flushed cooling system.
* I've changed rear axle outer bearings and gear oil.
* I've replaced all the brake pads and rotors.
* Replaced 2 brake calipers.
* Replaced both front wheel hub assemblies.
* Replaced 2 O2 sensors.
* Have no check engine light.
Anyone have any thoughts, comments, suggestions?
Thank you.
Thank you.
