My cam lifter job! Pictures
fadetoblack188
So my truck had the dreaded hemi lifter tick. Finally started misfiring. Cylinder 5. I was hoping to wait until warmer weather in NY to do this but the motor would misfire bad over 2500 rpm’s.
The oil pan was also weeping through and leaking. It’s a pretty big job with a 4wd truck to change it. So I just decided to pull the motor and do all the work inside the heated garage.
Here are some pictures. Thank you to everyone that helped on this board! Especially @Black1500Ram and @Wild one who was there when I had questions throughout the job. If anyone had any questions and looking to tackle there please inbox me I would be happy to help!
F
fadetoblack188
More pictures
ramffml
ramforum
Some of you guys are lucky you have the skills to do all that that's for sure.
Was it just the one lifter? I noticed it looks a lot darker than the other one, curious how it compares to the other 15 when it comes to carbon and oil stains on the side?
And one other thought from the peanut gallery - I hope you took the opportunity to replace all 16 plugs while it was out!
F
fadetoblack188
The plugs were already fairly new. I did those not to long ago. As long as you have the magnetic angle sockets it’s a breeze.
I will compare them with the others
F
fadetoblack188
Great work! How many miles on it? (sorry if I missed that).
How did you go about cleaning shavings out of the oil galleys? Or was it clean?
I saw some shavings in the pan but being I changed my pan there wasn’t much to clean there. I poured some oil through the galleys and run it run out and try and flush. My vvt solenoid had zero shavings on it. I still changed it. I used air to blow out block to with pan off.
156k miles
I will change oil and filter around 500 miles again. Also stuck a magnet on pan cause why not . I will pull magnet on next drain.
TotallyHucked
Gainesville, Ga
2017 Sport CCLWB
Nicely done. I'm trying to convince my dad to let us do his rather than paying a shop for a crate motor. I've had plenty of LS's torn down, I know we can do the Hemi. Trying to talk him into some mods "while we're in there" lol
Jeepwalker
WI
2012 Reg Cab, 4x4
156k miles
Thanks for the info. Had you considered pulling one of the main bearings..just to look? You probably know this more than I (from your research), are the bottom ends on these Hemi's pretty robust? Can they go a long distance if the rest of the valvetrain stays good? I've had some engines go well past 300k that were still in good shape (GM's/Jeeps). What's the consensus on these (valvetrain excluded)?
Good job, ..again!
Burla
2010 Hemi Reg Cab 4x4
Fantastic work. How much mechanic experience do you have? Been doing quite a bit or is this the largest job you've done? Did you even look at the cam bible thread here??
How much effort do you think it took to pull the engine compared to leaving it in? Which would you think would be easier? If you had it to do it over you would pull it again? Just for forum knowledge, clearly you wont have to do it again :)
F
fadetoblack188
mechanical experience is not crazy. in my early 20's i did some 1/4 racing with a mustang. Small block ford more straight forward then this, less parts. I did not build that motor on my own but with help from a friend who was older then me. I learned a lot watching my friends at the time. I have never actually paid anybody to fix any of my cars, I have always tackled everything my self. radiators, breaks, leaks, suspension, diagnosing, the usual stuff. I never worked as a mechanic or have any certifications.
I would say this has been the largest job I have done. yes
I did not look at the cam bible thread. I will def check it out though.
I dont think pulling the motor was horrible. I think I made the right choice especially with having to replace the leaking oil pan. Here in New York its cold around 30. Laying on my back and bent of the fenders in the cold and wind didn't sound fun. I figured I could get the motor out in a day and a half and get it in the heated garage, take my time and work on it in a t shirt. i only have a half garage which can be seen in the pictures. some good music playing and just taking my time.
Also i noticed some guys do the job without removing the oil pump. Me personally I am not gambling on that chain not accidently jumping a tooth on the crank gear behind the oil pump. for some reason i just didn't trust the zip tie trick and keeping tension on it. i am not saying its wrong I just dont like it. I personally wanted to see the marks on the crank gear and on a chain. Knowing the motor was a top dead center there was no guessing it's straight forward. I also felt if I was going in there and pulling that cover I wanted to replace what i could. Tensioner, guide, chain, oil pump, water pump etc.
The wiring harness can be intimidating, all the connections and spaghetti but a deep breath and one thing at a time you get through it. It all falls into place reassembling.
If I had to do it again that's a tricky question. 2wd car I would say leave it in in the truck. better access to lower the pan and pull the pick up and the oil pump and check that timing. I know there is a trick to drop the pick up with leaving the pan on as well. I would say if you don't need to worry about changing the oil pan and its warm out haha do it in the car. But i 100 percent do not regret my decision i think for my case it was def the right move. I do think that though it is very convenient working on the motor on a stand as opposed to over the fenders. so I am on the fence with that answer.
I didn't mean to go off on a rant but figured I would respond as best I could.
Davenator
