Need Help! 2014 2500 6.4l V8 Throwing Codes
CenCal Ram2500
Central Valley, Ca
6.4L V8
Need some help. Bought a ram 2500 from a family friend (the original owner) 8 months ago after her husband passed.
Around 2 months ago, got the Red Lightning Bolt (Service Electronic Throttle Control). When a diagnostic was ran, P2181 – Cooling System Performance came up. Mechanic replaced the Thermostat. CEC light came back on within a day. Same Code. Took back in, mechanic said there was air bubbles in radiator line, he flushed the air bubbles. 1 week later, CEC light came back on. Codes read P3449 – Cylinder 7 Deactivation Control Circuit, and P3441 – Cylinder 6 Deactivation Control Circuit. Took to mechanic, he put a wiring harness on order, but told me I was good to drive it around in the meantime. Since then (wiring harness not installed yet), codes P04D1 – EGR, P0128 – Low Coolant Temp, P040B – EGR Temp, and P219A – Bank 1 Air/Fuel Ratio Imbalance have came up.
Any thoughts? Through personal research, I have read that voltage/short issues can cause a couple of the codes. Does this sound plausible? Has anyone had an experience with anything similar?
2014 Ram 2500
Laramie Power Wagon
V8, HEMI, 6.4 Liter
Automatic, 6-Spd, 4WD
170,000 Miles
C
CenCal Ram2500
Central Valley, Ca
6.4L V8
P04D1 – EGR
P040B – EGR Temp
PREVIOUSLY
C
CenCal Ram2500
Central Valley, Ca
6.4L V8
Update: Reflashed/Reprogrammed the PCM. Now codes read:
P2311 – Ignition Coil 4 Secondary Circuit - Insufficient Ionziation
Bad PCM? Short/Ground issue? We are lost - Any thoughts on this would be greatly appreciated!
Daw14
Have your battery load tested , will throw codes sometimes when they are going dead.
Dodge 1500 4X4
Rochester, NY
X2 on have battery load tested, one better how old is the battery? you're this deep into it, I would have thought replacing the battery should have been your first option, I would replace your Parts cannon mechanic.
mjf84
Georgia
4.7L V8
Ever figure it out? I’m having same issues
AKJeeper
