Mordanger
Williamsville, MO
5.7L HEMI
Ok, notorious lifter issue fried my motor at 120k miles.
Bought a BRAND NEW 5.7 from MOPAR that came FROM MOPAR with NGK Iridium plugs.
ONLY re-used the Oil Pan, Valve Covers, & left the A/C system in tact.
20% larger injectors
BBK Shorty Headers
Spectre Air Intake
Edge CTS3 Tuner
Those were the only "upgrades" done. Had to pull the 20% injectors and buy another set of OEM because even with my EDGE Tuner on it, I couldn't adjust them out and it continued to run rich.
Now, I'm having "code P0300" - random misfires and cannot get it to stop. Any thoughts?
Running 91 Octane and feeling i should go ethanol free??
DILLIGAF
Canada
You need HP Tuner to tune it properly.
And why would you run bigger injectors on a stock motor, Instead of doing the 6.4L intake swap makes no sense to me if your looking for actual HP gains.
Could be a dozen things wrong, Get a good scanner and do some diag.
NCRaineman
NC
2019 1500 Classic
Spectre intake tells me all I need to know. That's pep-boys quality tuner crap which belongs on a Honda. Seems like you've got plenty of money to throw at the problem, so do it right.
Mordanger
Mordanger
Williamsville, MO
5.7L HEMI
Spectre= Junk put an OEM or 6.4 swap, because I'm sure there is metal in old one.
I'm a pipeliner that's only home on weekends. So I just got what I could to finish it off and get it running. The plan is a 6.4 swap. But because I only get a couple hours a week(if that) to do anything with it I just wanted it running lol.
Mordanger
Mordanger
Williamsville, MO
5.7L HEMI
The intake swap is coming, but as I told another, I'm a pipeliner and am lucky if I have a couple hours a week to work on it. So when I got close to it running I just got what I needed to get it running.
I looked at HP Tuner but alot of the articles I read had this edge tuner listed as top 3 and it was a little cheaper.
I'm the last in my family to cut corners, but I was just so tired of not hearing it lol.
UPDATE:
Put new OEM injectors and it fixed the running rich issue(as I figured it would) but now the P0300 code is still there and it is running so much rougher than before. ONE time it gave me P0301.
Removed, re-gapped and cleaned new plugs(NGK Iridiums)
Swapped coils around
Checked and tightened intake bolts
Checked wires & connections
Any thoughts on where to head next?
Cause I'm at the point of just taking it to the dealer and paying the $160 diag fee lmao...
